L
longdogs
OP, when you say you tightened everything up, do you mean with a spanner? The tails should be hand tight with maybe just a small nip up with a spanner but no more.
You have not used the wrong size tails because you would know instantly.
Are the tails twisting undone when you tighten the other end?
Is it possible to connect them temporarily under the sink so you can see where the leak is coming from.
Occasionally you get a tap which has not been manufactured correctly
