raden said:You normally replace what's broken ... that's how you get things working again
Which, by the sound of it, is almost certainly nothing to do with the motorized valve.
Come now ollski, you're dragging logic and reason back into the topic! After all, raden has spoken, and we all need to be carefulollski said:raden said:You normally replace what's broken ... that's how you get things working again
Raden,how would you tell if it's only the motor that needs replacing or the whole head??I mean how do you check 4 that? Then, when people advise you on replacing it for a Synchron, do they refer to the motor itself or the whole head or do Synchron do both?? Thank you.raden said:Raden, just made a difference between the actuator and the motor. I just thought they were one thing. 1)What is the difference between the two?
2) Which of the two do you normally replace then?
The motor which drives the actuator head can be purchased separately (if that's the problem) it drives the actuator and is significantly cheaper than the complete head
You replace the motor and see if the whole thing then works.dotto said:how would you tell if it's only the motor that needs replacing or the whole head??I mean how do you check 4 that?
Synchron is not a brand, it's a type of motor, so your question isn't answerable.dotto said:Then, when people advise you on replacing it for a Synchron, do they refer to the motor itself or the whole head or do Synchron do both?
Softus said:You replace the motor and see if the whole thing then works.dotto said:how would you tell if it's only the motor that needs replacing or the whole head??I mean how do you check 4 that?
Softus said:Synchron is not a brand, it's a type of motor, so your question isn't answerable.
No I didn't - you've added a question mark to the quoted text.Onetap said:Softus said:You replace the motor and see if the whole thing then works.?dotto said:how would you tell if it's only the motor that needs replacing or the whole head??I mean how do you check 4 that?
I certainly could, but invariably I wouldn't. If there's power to the motor and it isn't turning then measuring the windings is a waste of time.Onetap said:You'd test the windings with a resistance meter.
Onetap said:Synchron is a brand, they make synchronous motors.
http://www.hansen-motor.com/synchindex.html[/QUOTE]
I stand corrected, and humbly apologise for the misinformation. You learn somefink every day.
However, whilst the replacement motor might be from "Synchron", the replacement powerhead isn't.
Softus said:No I didn't - you've added a question mark to the quoted text.
The motor could be OK & the actuator gears could be seized. I'd just replace the whole actuator head.Softus said:I certainly could, but invariably I wouldn't. If there's power to the motor and it isn't turning then measuring the windings is a waste of time.Onetap said:You'd test the windings with a resistance meter.
To summarise everything:1)would i be right in changing the motor itself and if it still does not work ,buy an actuator separetly to fit with new Synchron motor since i do not know which of the two is faulty??2)Would it then be possible to buy the actuator by itself to fit with the new motor??...3)Or is it possible to check on both of them separately with a voltage tester to see which one is not working???? Please answer to the three questions!!!! Thank u ever so much..Onetap said:Softus said:No I didn't - you've added a question mark to the quoted text.
Guilty, unintentional error in cutting & pasting, now corrected.
However, adventures with 230V could be a novel experience for some users, so I didn't want to suggest powering things up with the covers off. I'm sure you know what you're doing, I'm sure many others don't.
dotto said:To summarise everything,would i be right in changing the motor itself and if it still does not work ,buy an actuator separetly to fit with new Synchron motor since i do not know which of the two is faulty??
No it isn't! The valve head, I mean the actuator, not the valve itself, by which I mean the brass bit , can jam solid. I know cos I just changed one only to find there was nowt wrong with it.
OK.ChrisR said:Not all synchronous motors are made by Synchron.
OK.ChrisR said:Not all motorised valve motors are made by Synchron.
OK.ChrisR said:Honeywell original motors are all Synchron motors afaik, but could have been replaced by a non-Synchron motor.
Fair play.dotto said:Guilty, unintentional error in cutting & pasting, now corrected.
No.dotto said:To summarise everything:1)would i be right in changing the motor itself and if it still does not work ,buy an actuator separetly to fit with new Synchron motor since i do not know which of the two is faulty??
No.dotto said:2)Would it then be possible to buy the actuator by itself to fit with the new motor??
Not really, i.e. not easily.dotto said:3)Or is it possible to check on both of them separately with a voltage tester to see which one is not working????
Ho Softus and thank u all very much 4 your time and i apologise if this issue is dragging on. I read Ollski post. I have not checked for voltage on the cylinder stat because when i call 4 HW the boiler fires up, which i simplyassumed that the Cylinder stat was making the switch 4 boiler and the pump and therefore nothing wrong with cylinder stat....or am i wrong in assuming that?Softus said:Fair play.dotto said:Guilty, unintentional error in cutting & pasting, now corrected.
As Crystal has observed, the best advice available to you was first given by ollski. You're getting very hung up on the idea of replacing MZV components when you haven't even identified the fault.
