Mould and Wet Ply - Keep or Discard?
30 Sep 2012
London
I have searched, found a few bits of info, but could do with some quick help:
I have done a loft conversion, with a plywood flat roof. I'll cut to the chase - some of the ply has got wet. I am now drying it, but there is some mould - green bits, grey fluff and some white slimy stuff, here and there. Not a lot but a bit. Almost no delamitation it seems, but some ply got pretty wet and stayed wet for some 4+ weeks.
Simple Q: If I dry the ply out, will it be fine to use, or should I discard it if there has been mould growing?
Many thanks
Jon
heeelllooo and welcome greenlikeapples :D :D :D
how thick is the ply and what centers are the timbers
Hi Big All
I went a little overboard - it's 18mm ply with a 9mm ply on top so we can walk on it
Joists are at 400 centres although there is 60mm of continuous sound insulation and heat insulation between the ply and the joists
Cheers
thats what i am getting at really if you've overspecked you have redundancy so can put up with a bit off delamination no probs
i would just clean the surface with water and bleach let them fully dry for several days
chuck it flat between 2 fence posts and jump on it
it will off course bow probably till it touches the ground but should show up any weaknesses around the edges
Hi
Great thanks - that is the conclusion I had come to - let it dry and bleach on the bits with mould
What do you reckon - it has been on the roof in the wind and the sun all day today, some of yesterday, and will be same again tomorrow (well wind and air if not sun) - you think this is enough, or a few more days inside or under tarps?
Jon
i would try and get it below around at least 16% ideally 12 or 13%
