It depends on the insulation of the wall. if it's a well built modern construction then not much heat will transfer through it and the foil will have little effect. If the wall is a crappy old stud wall with little or no insulation then heat transfer will be higher and the foil will have greater effect. Having said that, if this wall is a crappy old etc... etc... then you'd be better off getting it properly insulated before doing anything else.
Top job would be remove layer of plasterboard, insulate with PUR foam, replace plasterboard, make good. It sounds like a bit of a job but heating is so expensive these days it would probably pay for itself fairly quickly. If this wall is a separating wall do you not get a lot of sound transfer as well?It depends on the insulation of the wall. if it's a well built modern construction then not much heat will transfer through it and the foil will have little effect. If the wall is a crappy old stud wall with little or no insulation then heat transfer will be higher and the foil will have greater effect. Having said that, if this wall is a crappy old etc... etc... then you'd be better off getting it properly insulated before doing anything else.
Yeah good point. It is a crap old stud wall. It sounds hollow. What insulation should be done to it?
Air is warmed by convection.
