- Joined
- 26 Nov 2016
- Messages
- 3
- Reaction score
- 0
- Country
Hello.
I have been reading this forum for a while but not posted anything yet. However, I can't find anything about a problem like this so thought I would ask. The plumbers we used to install it were awful so really not keen to go back to them!
We have a solid fuel stove with a back boiler which does the hot water and central heating. This is downstairs. There is one radiator and the hot water tank upstairs, there are three radiators downstairs.
The hot water and upstairs radiator are fine. However, the downstairs radiators which work from the pump are not getting hot at all. The pump is a one year old Grundfos UPS2.
There is a power supply to the pump, then a control unit of some sort with it's own switch. All fuses are fine and there is no loose wiring anywhere.
With the stove (and upstairs radiator) on the pipes on both sides of the pump remain stone cold. Is this odd, or would it only draw hot water through if the pump was running?
The little red light on the power supply for the pump (13amp) is on when the stove is off, but once the stove gets up to temperature it goes off. I have no idea what is going on here.
Everything worked fine last winter so I assume it's all wired up properly.
Any ideas what, and indeed how, I should check next?
Thanks,
Andy H
Thanks,
Andy H
