Hi All
I was called to a printing company to look at a 3phase seam welding machine as users were reporting getting shocks from it.
I has a 4mm earth bond to the movable seam section, but no bond on the main table.
So I decided to take a 10mm bond from the connection box on the wall and measure the voltage between it and the metalwork of the machine.
I connected black crock clip to 10mm cable going back to the wall mounted isolator switch earth bonding point and the the red clip to the exposed metal work of the machine.
When the machine was used to make a weld. My connected meter went up in smoke after lighting up like firework.
The machine is a
Digicon Micro Systems Seam welding machine for welding fabrics.
I have lock off the machine and said it is not safe to use.
Any ideas
The machine is a
Any ideas
