I have just had a new Baxi duo tec boiler fitted and an error 133 is occuring i have had the baxi engineer out and he says the fault is electrical and due to the following
L-N - 230V
L-E - 136V
N-E - 103V
We have also recently had a TNCS system installed however the Main earthing conductor hasnt been connected to the incoming supply by the electricity board.
Could this be the problem ?
Or could the N-E fault be influenced from a fault from other circuits ?
However all other circuits in the household work fine but the earth has a high voltage ( Enough to get a little shock when being worked on ).
Any help would be much appreciated
Thanks in advance
Stefan
L-N - 230V
L-E - 136V
N-E - 103V
Thanks in advance
Stefan
