Hi at the moment i have a garage type 2 way ip rated consumer unit fitted in a narrowboat. The shore power supply is around 6amps 1200watts this is connected into a cu 40 amp rcd main switch leading to two 6 amp mcb's. One mcb is used for the kitchen area the other mcb is used in the living area a total of 5 double sockets and one single socket.
I wish to add an electrical circuit in the bedroom consisting of a one double socket and a low watt wall light and a further circuit consisting of one waterproof socket on the stern of the boat. My question is whats the best way to do this, come straight out of the living room mcb for the extra sockets, spur of the living room circuit for the extra two sockets, get a new 4/5 way rcd cu wire in each separate circuit and if so has this got to be ip rated being on a boat, although it is inside the boat it is in a locker room where there is a mushroom air vent above it.
Many Thanks to the experts in advance Andy
