I've noticed a crack appearing in my toilets cistern just below the flush handle running horizontally. The crack is about 100mm long and isn't leaking but there is also a smaller crack running up towards the flush handle.
The cistern was orginally fitted by the council maybe 20-25 years ago (possibly longer), we bought the house a few years ago so can't get the council to fix it.
The cistern is a Dudley but i'm not sure what model. Its dimentions are approx 490mm wide * 235mm high * 195mm deep and there is what i'm guessing a model number of D57-B1 MK2A in the bottom of it. The water inlet and flush are at the right and the overflow outlet is at the left (when facing the toilet). The lid has a plastic screw in the center of it the screws into the top of the syphon. The syphon is a Dudley Turbo 88 and i'd like to be able to reuse this if possible.
Can anyone recomend a replacement cistern that's not too expensive and a good place to get one from?
Cheers
Cheers
