Need advice adding insulation to a stud wall
OM2
18 Jan 2007
I had builders build a stud wall and insulate the roof in my garage - so I can work there (with a heater if required) in the winter
Everything looks ok and I'm happy with the result
But... I've just checked the edges of the stud wall that has had plaster boards put on...
There's a draught coming in!!
What do I do?
How do I get rid of the draught?
When getting advice about building a stud wall on this forum, I think someone mentioned foam that could be sprayed around the stud wall
I can't find any spray foam
The only thing I can find are stick on foam excluders - that you use for doors and windows
What should I be looking for?
OM
Don't you have Google?
http://tooltray.com/Expanding-Fille...ping?gclid=CPawh47MhbICFVMbtAodzkwAsg[/QUOTE]
awesome
just what i need
but what should i do?
the gaps where air comes in is narrow
the best solution i can think of is to remove the plasterboard and then apply the foam and then screw the plasterboards back
this would be a massive problem as far as i can see
or should i just try and fill the gaps on the plaster board?
also... should i think about filling from the other side of the garage door?
Maybe his Google is broken?
lol
no, it's just that i'm not as clued up as u guys
i was searching for 'insulating foam' - as i said, all i could find where those strips for doors and windows
Poke a screwdriver thru the plasterboard and poke foam tube thru to seal, small hole to fill when set.
thanks for the reply - i haven't been able to reply until now
not sure if this would work
the air is coming through the side gaps. see the following pic:
any ideas?
the only logical thing i can think of is removing the plaster boards and applying expansion foam - but just afraid i might have trouble putting boards back if the foam has set
suggestion: would it be a good idea to take off plaster boards, apply foam and then quickly put boards back - allowing the foam to seal?
is that a good or bad idea?
also: would it be a good idea to apply foam on the other side of the garage door? the concern here is that the foam would stick out and not look very nice?
any advice would be great
thanks
Looks tidy , just run dec caulk down seams and fill.
ok... this sounds a lot better solution to me - will be much neater
and given that the wall won't be moving, caulk should be ok
would u recommend anything on the outside - the garage door itself?
i'll take a pic of this later and will update this post
thanks
EDIT: i've just taken a pic of the garage door to illustrate
the gap is all around the garage door - behind it is now insulation material contained within a stud wall
can i, should i do anything about the gap on this side?
see below for the pic i took:
@foxhole, i think i'd like to use foam - but am just afraid what it will turn out like
just want to know if is easy to sculpture before it fully dries
importantly: if i make a complete mess, how easy is it to remove?
thanks
You don't touch it before it dries, once dry can be carved easily [bread knife can be used].Spray area with water before foam as it helps it expand, use sparingly you will find it expands far further than anticipated, don't be in a hurry to trim any still wet will make a mess.[/b]
@foxhole, that sounds like good advice
i'll give it a go now
thanks
