Need help in finding the right connector
I have bought a used Jacuzzi bath and found the waste pipe of a different size then you would normally find
It’s a flexible waste hose which at the trap is the normal 40mm but the other end is only 28.5 or there a bout’s
At the trap it look like it’s glued/melted on (like from manufacturing new) and cannot be taken off
Is there a connector to get this one back from 28.5 to 40mm solvent
The 28.5 is the inside measurement, compression will not work as the sleeve is very thin and flexible (the like you see on the end of a washing machine waste hose) so therefore it needs something to go into the pipe and then fixed with a jubilee clip
I only have seen the 28.5 for caravan waste pipe
