NEFF Dishwasher S5443
12 May 2011
Hull
Have a Neff S5443X2GB/44
It wont finish a cycle.
water not getting hot.
Continues even if open the door.
No lights on.
Can't reset it.
Would guess that it is heater element.
How do I get to it?
Does anyone have any resistance values?
Thank you.
Graham.
If the drain pump keeps running with the door open,you have a flooded base.Tip the machine backwards with towels at the ready,should work then,but you have to find the cause of the leak.If you use the search facility you will find further info.
Thanks for your help.
Tried tipping machine backwards,very little water came out and machine still the same.Any more ideas.?
