In the summer our neighbour had their soffit and guttering replaced. The soffit was originally solid, but they replaced it with plastic soffit with slits all along it.
Our house was built in 1955. We have cavity wall insulation. It is a terraced and between us and nextdoor there is a shared pathway to the back gardens. At the front of the house they have a larger room which goes over the pathway, and at the back of the house we have the larger room which goes over the pathway. In our back bedroom we now have a damp patch right at the top in the corner (joining onto their house). Because of the staggered bedrooms over the path some of their new soffit is over our bedroom (corresponds with the damp patch). I have been in the loft to look and where their soffit overlaps onto our house their builders removed our loft insulation, so in this corner there is no insulation over the soffit (all of our soffit is covered with insulation) and because of all the slits in it, it is now much colder and more drafty in our loft. Thats about all I could see balancing on the beams with limited space in the eaves!
The damp patch is literally just in this corner on the wall and a bit on the ceiling. We have never had a damp problem in our house before now.
My question is, is it likely that the damp patch is caused by condensation where they created a cold patch by removing the insulation? Or is it more likely something is leaking or in the wall cavity causing the damp? Should I try covering back over where they took the insulation away from to see if that helps? Or am I going to need to get someone up on a ladder to have a look for me?
Thanks for any advice you have!!
