Thanks for your reply what you have said I have done all that using the instructions with the heat link no luck boiler doesn't come on when I press the nest logo on the heat link
OK, post a photo of the connections at the Heatlink and I will have a look.
Also if you have removed a wired thermostat where the wires came from and the link between the switched lives.
Don't take the P out of the forum rules. They are there for a reason. When a post is hijacked it can result in a lot of confusion when trying to discuss two separate projects on one thread. You will also usually get a better response with your own new thread. Fortunately in this case azzwuff isn't adding anything.
