Nest hot water schedule not working?
27 Jan 2008
Llanfair Caereinion, Nr Welshpool
If I select boost then the hot water heats for ½ hour as software says, but the schedule is set to heat hot water from 7 am to 8 am this does not work.
any ideas what I am doing wrong?
Found it, on the thermostat in settings have to enable schedule, now on PC when selecting domestic hot water it alternates "Press to Boost" and "Until Tue 07:00" it did not do that before. And yes did heat water when I pressed boost and selected 30 minutes.
The instructions on how to fit Nest are good, but the instructions on how to use Nest seemed lacking, at first I had no icon for hot water, seems my boiler type has to be selected as "other" still unsure about the TRV heads, with the phone app the hall radiator is set to follow Nest, but this is not reflected in the PC program.
So really not sure if set or not?
