Hi everyone, first post here. Thanks in advance for any replies received.
I have found this site very helpful in the past but can't seem to find an answer to my question.
I've just finished major works to my house and had a new heating system installed. I have a Vaillant boiler (separate controls for heating and water) and an ariston hot water tank. The system is unvented. I have one thermostat (dial) in the house. My question was:
If I set the hot water tank at max temp (there is a dial with no numbers), and the boiler hot water at, say, 50, would the temperature be determined by the tank or boiler.
Is it the same for heating i.e. if I set the heating at max on the boiler and, say 20, on the thermostat.
I suppose what I'm asking is what is the 'primary controller' for heat output.
I have set up the two instances above but the water and heating are extremely hot in both cases i.e. the thermostat for heating and boiler control for water don't seem to have any effect. The plumber in the building team said the two instances above should work but, as I say, I have tried and it doesn't seem to.
Many thanks again.
Many thanks again.
