I am in the middle of replacing a hot water cylinder and as this is for hot water via emersion heater only I have fitted a direct cylinder.
My question is I have one outlet on the back that I have capped off two on the front (top and bottom) and the normal one on the top.
of the two on the front the bottom is water in from tank in loft as per old cylinder
I am in the process of fitting the vent pipe on the top outlet.
Should I take hot water to the taps from this (as old cylinder) or is it ok to take the hot from the other outlet on the front (top) or is there a reason for taking the hot water from the same as the vent pipe?
many thanks
many thanks
