We have recently had our old cylinder heater and boiler replaced with a glow-worm combi boiler. This has been fitted in our old cylinder cupboard behind our bath and we have had a new thermostatic mixer shower fitted to run off this. Before these were fitted we also had a new water system fitted by the water company as we used to be on a shared system.
Our installer had the boiler and shower fitted by Tuesday evening and the shower pressure was fine, although the shower didn’t get very hot even with the temperature knob completely on. He needed to come back on Wednesday to fit the thermostat etc and I mentioned the heat issue to him.
When we came home from work yesterday, the heat of the shower is better but the power has gone a bit weird. When you turn the shower on the power is fine but then it drops significantly almost straight away.
We noticed the pressure on the display on the boiler was 0.9bar and it says in the manual if it’s less than 1.0bar to add pressure. So we did this and the pressure is now at 2.4bar but the shower is not working any better.
I was under the impression that if we had a new water system, new combi boiler and new shower fitted we would have a pretty good shower!
I was wondering if anyone had any idea what the problem might be? I don’t really want to have to get my plumber back out if it’s a relatively simple thing to fix…
Thanks for your advice
Kate
Kate
