- Joined
- 3 Jun 2018
- Messages
- 48
- Reaction score
- 1
- Country
Tap will be up/down for on off.
To left for hot right for cold.
The centre position in relation to handle can be adjusted by where its clamped down..
when you lift up the top lever you get cold water by default, if you want hot water you have to turn it anti clockwise to your right. It doesn't turn left at all. I want it to do the opposite, turn it clockwise to your left get hot water.Tap will be up/down for on off.
I have attached two photos, the first showing the cold water position and the second showing hot water. I basically want it so you turn the top lever all way left instead of right.I don't understand what's turning.
It's a monobloc, left for hot, right for cold and lift to open.
Nothing to turn.
Thanks. Isn't it the cartridge inside the tap that determines which way it turns? The issue is that the turn doesn't turn left and right, only right. On my bathroom tap you turn it left to get hot water and turn it right to get cold water. On this tap it only turns to the right for hot water but I would it to turn to the left for hot water.Only one pic visible. It sounds like the tap body needs to be turned on the sink ,and your hot and cold connections to the tap are the wrong way around.
Hot should be lever to the left and cold to the right. The indice on the tap is showing the opposite ,but that can be pulled out and repositioned
I've made a video showing how the tap turns. Can you confirm it's been fitted incorrectly?Your tap handle has a mid point between far left and far right ,at which it will blend hot and cold water together.
The tap tails below the sink are connected incorrectly ,for you to get hot on the left and cold on the right they need to be swapped over on the supply pipes.
The cartridge is irrelevant.
But it's not the tap that's faulty, the installers can change the orientation?Put it this way ,it's not conventional !! There is no law that states a mono bloc tap has to be fitted in a specific orientation ,but yours is the only one I have ever seen fitted like that !!
