Morning all,
We live in a three floor property, the current system is setup with a zone valve for each floor, this is then controlled through a three way timer and TRVs, there is no master thermostat, it relies on the boiler stat for starting/stopping the boiler. The boiler is a Worcester Oil Combi.
We'd like to upgrade the system and I've had a quote for as follows:
Remove old boiler, install a Danesmoor 18/25 Utility boiler, install a 200L unvented cylinder with immersion heater backup.
Install a Worcester Wave control system, one wave system per zone.
All of this for £4880
Does that sound reasonable?
My main concern is with the control system, the three separate wave systems doesn't sound like the best solution so I'm thinking perhaps we'd be better off with an Evohome system, but we'd only need it to control the three zone valves rather than putting on separate rad valves, and then put a thermostart into each zone?
Do the Oil system boilers modulate? If so can Evohome talk to a Worcester and tell it to modulate?
Any help would be really useful, it seems that most installers I've spoken to don't really know about the Evohome system.
