Last month I had a new roof extension tiled with Calderdale dark grey concrete on top of breathable membrane and had some problems in the first week with leaks on the hips and leaks near and around these areas these have now been fixed after multiple visits as the dry hip system was not fitted correctly.
The visits resulted in 1) replacing the stick down bits on the dry hip system as the guys originally stuck it on top of dusty tiles and 2) replacing loads tiles that were cracked.
After a 2 weeks of no leaks, a little moisture, i have started to get leaking in the roof by the gable wall and down one side of the garage roof.
The BI has been out and checked the pitch and it is above what is recommended at 19.5 deg (not massive but fine) so we are OK there but he seems to think that the problem may lie in the lead flashing along the gable wall and down the gable wall where the pitch roof hip joins.
BI suggested I put on a longer connection to the down pipe to take the rain water away from the lead which stopped the majority of the leaking but there still seems to be a bit coming through with heavy rain.
The job is covered by a guarantee so i can get the guy out as many times as needed but before i get these guys out for the 6th time can someone take a look at these pics and see if the BI is right? I don't doubt the BI I'm not sure how the roofer is going to take being told his job from a BI?
So I'm just looking for guidance please.
Cheers
Pete[/img]
Cheers
Pete[/img]
