I have a newly installed Bathstore Atlas shower which is not draining at the same rate as water goes in. Even if the trap in the shower tray is disassembled the water is still not drawn away. Water sits in the waste with the level going up an down as if there's an airlock.
I am going to get a plunger today in case the pipe is blocked - which I doubt.
The plumber has used 45mm o/d (innacurate measurement) pipe under a 3.8 metre floor going out through the wall to the waste stack. The shower base is mounted on a 4" base. Has sufficient drainage capability been designed in?
Any advice much appreciated as sooner or later the kids are gonna flood the bathroom floor.
