Thanks for the reply, yes its a honeywell dt90e non programmable room stat, i've fitted the honeywell st9400c which is set to miniprogrammer mode.
From what was talked about earlier, i thought if there was a way of delaying the pump shut off for a few seconds, the residual heat would still be pumped into the system, rather than it sitting in the boiler & bubbling away.
I've been up in the loft, the tank seems to be filling ok, the water seems to be clear, slight colour on the bottom of the tank. While i was up there there was no water coming out of the Vent pipe, though it did seem damp, as if something had come out recently.
When the engineer was here he stripped the fire down & pulled everything apart, cleaned it with wire brush & put it back together. This was done when the system had been drained but before the sludge treatment had been used, should this have been done after?
When i've been checking the rads for air the water out of all the rads has been clear, one rad put a bit of black water out for a while, but that one is clear now.
Any suggestions? Wife is getting worried about the noise incase it "blows up" i dont think its that bad personally.
Thanks.
