fitting heating in my m8's new house at the moment.
his wife came in today and asked if possible to make the big cupboard in the hall into a downstairs loo.
have had a look and it not easy to get the waste away .
the soil stack for the property is approx 6m away but the outside grouind level is pretty much the same as floor level.
was thinking about a dreaded saniflo but the waste would need to go approx 4m horizontal before rising up to the stack which i believe is no good ?
other possible option is digging down to the waste pipe undergound which i assume is clay ( house built around 1900) and connecting into that.
is there a depth that the clay waste should be at as i would like to know if i will have enough fall under the floor and out through the house to connect into it with 100mm sol pipe .
does he need permission to do this from anyone
thanks
thanks
