Hi Everyone,
About time I stepped from out of the shadows...converting my garage into a bedroom was hoping to run a few things by all of you.
I'm taking out the garage door and window above it, replacing it all with a metre high block(2 skins, cavity)wall and pvc window above. There is an existing concrete lintel which i will not disturb and fit the window to.
The sides of the window I'll build up with half blocks. Using partial fill insulation, and thermabate to close the cavity.
Now the little problem. I think the house wall may be CHB's filled in with concrete. Whats the best way to find out? whack off some of the render?So if I was building this cavity block wall how would I build it in to the other walls if they are different block sizes. Build the wall freestanding, do a vertical dpc and brace it to the other walls?
I think my understanding is a little twisted here!
Any Help Much Appreciated..!!!!!
curadh
curadh
