Please HELP!!!
I have had the family bathroom tiled and a new shower fitted. The shower in the ensuite works fine, but the shower in the family bathroom pulses when turned on. Also the pressure is low, if i turn to hot water only or cold water only then it stops pulsing but still has low pressure, but the minute i mix cold and hot water it starts to pulse and the pump won't switch off even though i had turned off the shower. The pump also starts when i turn the hot water on in the kitchen sink. Do i need to replace the pump or is there a problem with the system?
