Niglon make an IP68 SWA Joint box.
It's a round polycarb drum with perimeter steel plate to bond the glands without using banjo or earthing/piranha nuts. 4 way entry, use as you need. Trouser type or H box (like the rare Pratley) would be better.
Either my eyesight is going, or the lid is simply screw-on?!
Surely reg 412-03-04 is not complied with?
"Where it is necessary to remove a barrier or to open an enclosure or to remove a part of an enclosure, one or more of the following requirements shall be satisfied...
"i) the removal or opening shall be possible only by use of a key or tool".
I know it's Monday, but the weekend was not that cold...
