- Joined
- 27 May 2017
- Messages
- 3
- Reaction score
- 0
- Country
Car:
Nissan Micra Initia 1.2l
2005/2006
55k miles
My car has recently started squeaking. It happens when you are travelling at low speeds then accelerate. It also does the same noise when you take your foot of the accelerator and the car lurches. It sounds like it is coming from the front right of the car just in front of the driver.
The noise doesn't happen when the car is off and press the clutch ,accelerator or breaks. It also doesn't make the noise if you accelerate in neutral only when in gear and moving. If you rock the car the suspension doesn't make any noise or squeaks.
I will post an audio clip of the car you can hear it at 12 seconds in. I got it to make the noise by parking the car and just rocking it backwards on forwards with the hand break on. The noise was made when the back end initially lifts up and then happens again when the clutch is pressed and the back end comes back down. It also happens when turning the car off, the noise only starts to happen when the car gets warm, and is rather loud
audio clip:
https://soundcloud.com/user-405606526/carnoise
Not much to go off but anything helps thanks!
2005/2006
55k miles
audio clip:
