- Joined
- 11 Mar 2007
- Messages
- 4
- Reaction score
- 0
- Country
Looking for a bit of help, Ive no heat in 1 rad, its the rad furthest away from the boiler ( I had a small leak in a pipe fixed and since then it started, want to see if I can do it myself before I call back the plumber) and no hot water, Ive tried to bleed it but all that comes out is water, the pipes leading to and from the rad are stone cold too but I cant trace where these pipes come from exactly, Ive been up in the attic and the pipes going to that region are hot, the pipes going to the hotwater cylinder are also cold, again near the rad with the problem
The pressure is about right at 1bar
Would I be right in saying that if there is a bubble in the system, I just keep on bleeding the rad till it comes out.
