Hello,
I've recently had a plumber complete a fair amount of work laying some new copper pipes to supply water to our garage, moving the location of our stop tap, new kitchen & utility drainage, and the hanging of a couple of radiators.
The plumber was here Friday for 8-ish hours, during which time the system was drained.
Subsequently, we've noticed over the weekend that there's been no hot water and have had to use the immersion heater to get any hot water.
We have experienced similar issues in the past when plumbers have been to carry out work, and it's my understanding that the Honeywell Motorized valves can often get stuck/give up working when the water has been drained from the system. And so as a result, we'd like to understand what's failing in the system so we can replace it ourselves instead of having to pay for the plumber to come back and fix the issue.
We have a Drayton Wiser Thermostat control kit and a gravity-fed system. If we boost the water, the boiler receives the call for hot water and shows a working/burning code, so we believe it must be one of the motorized valves that have failed once again.
I've attached a photo of our hot water tank, and there appears to be 2 motorized valves. However, I'm not sure which one I need to change possibly. The central heating is working as normal, and radiators get hot when requested, so I don't want to interfere with that working as normal if I can help it.
Is it possible to tell from the photo which one I should look to replace?
Thanks for your help.
