Yes it does, so it’s the honeywell one (metal box). Is there a demand on for anything now?Does this help
Yes that’s ok. Is there a call for anything on Hive now?The wiring from the metal box goes to 6 7 and 8
This is likely the problem, it’s possibly the motor jamming.It seems when I turn on hot water the actuator isn't moving across to open. If u then manually move it across and turn hot water off the actuator moves across to closed itself.
Depends on what boiler, a lot do have just power to them, but only fire up when the switch live makes in the valve.Silly question also. Should the boiler be on all the time? As in have power to it even if hot water tank is full and heating isn't on
No Andy wrong one lol
