Went to run my bath this a.m. and found the water barely warm though the hot water had been set to come on for 2 hrs from 7 a.m. I noticed the rads were hot though the hall stat didn't click off when I turned it down and was only on l8 before doing so. I clicked the h.w. button back on (it had gone off by then) at the programmer and waited for an hour or more before running the hot tap again; no improvement but the rads were still hot though the c.h. was off at the programmer and the hall stat turned well down. Does anyone have any clues as to what might have gone wrong? I checked that the cylinder stat was set at 60, which I think is correct. I looked at the valve fixed to the pipe about a third of the way from the bottom and saw that at one end of the slot it said MAN ON and at the other AUTO and the lever was at the Auto end. Is this correct? I wondered whether it might have got knocked when I put a clothes airer into the airing cupboard. Incidentally, the towel rail was also hot. I can't understand how we can be getting heating when the heating button is off and the roomstat turned down. Would appreciate some advice, please.
