hi,
I have a boiler that is working and providing central heating ok but I can get no hot water, just luke warm
The boiler lights to heat the water, the pump works and all the pipes are hot.
I have checked :-
1) The thermostat on the hot water cylinder
2) the immersion heater does give hot water
3) The pressure release value also gives hot water when pushed
4) manually pushing the value to the central heating that then started to heat the radiators
5) There is no air in the radiators
The only think that I think might be the problem is an "air pocket".The pressure release did drip every minute and now doesn't
I am going to drain the central heating system next.
Any other suggestions ?
I have checked :-
