Also, with your multimeter set to resistance, measure between the two lugs on your bulb, it should have a low reading. I know it is new but its not unknown for new bulbs to be faulty.
but it is sold in the UK - the company is now owned by Fluke, and I guess they haven't got all the websites sorted out yet - contact them (http://www.fluke.co.uk) for info on where to buy.
Very cunningly....... it probably charges a ""battery"" when the switch is off and there is 230 volts available.
And I agree IF no volts between red and earth AND no volts between black and earth THEN there is a broken wire or connection somewhere and NOT a short circuit.
between the live wire and the switch wire.. there is a path back to the neutral through the lamp..
if you put another lamp of equal rating across the live and switch wires it will light both lamps at half brightness..
stupid question.. did you check the fuse again?
if it blew the first one then there's a chance it blew the replacement the first time you switched it on..
