Hi all, new to the forum here so hopefully somebody will be able to give advice/solution to my problem.
In a nutshell, I've had a water tank installed in the loft and a power shower in the bathroom and it's creating a fair bit of noise. The pump is a salamander pump in case that's of any relevance.
When the shower is run the pump is very loud, obviously because it is pulling the water up to the tank in the loft. However, it can be heard downstairs in the living room to the point where you have to turn the television volume up. Is that just how loud the noise should be?
Also, after hot water has been run, I can hear the pipes all the way through the house and the only way I can stop it at the moment is to turn the heating, hot water and water tank off. It causes particular issues at night when trying to sleep.
Hopefully that all makes sense. Thanks for any help.
