I've been refurbing one of two semi's (the other was done by someone else). Some of you may have seen my thread about cracked plaster on one wall, and unfortunately that same wall is presenting me with another issue ![Frown :( :(](data:image/gif;base64,R0lGODlhAQABAIAAAAAAAP///yH5BAEAAAAALAAAAAABAAEAAAIBRAA7)
There is excessive high frequency (TV, voices, alarm keypad) sound passing from the neighours. It is so bad that even the interior stud walls seem to pass less sound then the party wall.
The odd thing is that the neighbours don't appear to have the same issue, or atleast not to the same extent. I've been in there a couple of times for other reasons and haven't heard sound from my house (TV was left on for example).
Having seen both buildings stripped back, the following appear to be the same:
- Breeze Block Party wall
- Bricks between floors where joists enter wall
- 1m basement below both properties
- Joists above and below floor in question run to party wall
The differences I can see are:
- We have removed chimneys and covered with cement.
- We have 6mm fiberboard underlay and 9mm laminate, they have solid wood and carpet on floor above.
- There was a wooden wall which both sides have removed to create through lounge, we have placed a beam (running to party wall) here at advice of structural engineer, I'm not sure if other side has done so.
- We have rendered wall with hardwall (to level with cemented chimneys etc) then a layer of plasterboard (dot and dab and screwed straight onto hardwall). (If you've read my other thread you will know why we eventually went this route). They have 2x2 (or 2x4) frame then plasterboard. Given the other issues the new neighbours have with the work of the builder, I would doubt he did any other work to wall.
I've probably missed something, so will update when it comes to me.
Having read other threads I have identified/eliminated the following:
1) One of the chimney stacks has an electric fire on their side, which has a big fake flume type hole in it. I've asked them to seal the chimney above this, as that is undoubtedly allowing sound into the cavity behind.
2) The sound ingress is not restricted to chimney areas, infact they have placed their TV between the two chimney breasts and the sound levels are higher here.
3) My TV and speakers are on the opposite wall, which may be why they can't hear us as much, when they first moved in she did say they could hear us, but her husband said not.
4) I can't hear any sound coming through windows, therefore it is not flanking from this direction.
5) I can't hear any sound coming from floor, therefore I don't believe it is flanking from this direction.
6) I can hear some noise in the floor above (the ceiling of the room in question), therefore it could be flanking where the joists enter the wall.
7) When next door advising the neighbours on an issue they had on the thrid floor, I turned the speakers on in my bathroom (on other side of wall, and can control speakers over wi-fi), I could hear them through the wall. Therefore there is an issue on this floor in their direction. Again there is an old chimney on the same breast on this floor, so I suspect that is contributing.
My original conclusion was that it was due to the electric chimney on the ground floor. However, now they have placed the TV between the breasts, it is clear that is definately not the only issue. My current suspicion/hope is that it is flanking via the joist holes and then travelling down the small cavity I have between the plasterboard and hardwall. I will have to remove the skirting to lift the laminate, but atleast this is solvable.
However, the fact they can't hear as much as us is really confusing me. It leads me to believe there are bigger holes on their side funneling the sound through to smaller holes on our side. And therefore in the reverse direction not as much sound is getting through. Given how much we can hear, I should have definately have heard something through the wall when I've visited.
Sorry for the long winded post, just wanted to convey as much information as possible. Any advice and pointers will be greatly appreciated. Just hoping I don't have to redo this damn wall again![Frown :( :(](data:image/gif;base64,R0lGODlhAQABAIAAAAAAAP///yH5BAEAAAAALAAAAAABAAEAAAIBRAA7)
