Any ideas? The circ pump on my central heating system (Grundfos) is positioned around 1.6m above the hot water outlet of the boiler. When the pump is running it sounds as if the pump gets so far then a column of water falls back into the boiler and then the pump lets out an almighty snore. To me it sounds as if the NPSHR to allow the pump to operate correctly exceeds the NPSHA due to the 1.6m difference. I am not sure what model of Grundfos pump it is (it is a 3 speeder and red in colour, I will need to creep up in the cold loft!) but adjusting the speeds makes no difference to noise.
Is the NPSHR theory possibly the case or am I talking b*llocks?
Any replies/ideas received are much appreciated.
