noisy taps
how much more noise
A bit, probably :LOL:
If excessive you can add a pressure reducing or flow controlling valve (or squash some microbore..)
Don't use a partly shut ballofix cos they make a din.
ChrisR said:
how much more noise
ChrisR can you recommend any ''quiet '' taps that are similar ?
timbalcombe said:
I find my quarter turns are only noisy when water is not at full.
Makes a hell of a racket.
Ballofix is that the same as this?
http://www.screwfix.com/app/sfd/cat/pro.jsp?cId=100121&ts=41704&id=16505[/QUOTE]
the taps sound like a drill when partially opened !! :cry: :cry: too
noisy esp. at night .
They also have a narrower spout /body compared to old taps , will
try ChrisR flow restrictors solution when plumber comes back .
If that doesn't cure the noise then replacement taps is best solution
for bath ( don't want to restrict flow will take to long to fill up).
