Noisy toilet float valve
29 Aug 2020
I have a brass float valve that's suddenly started squealing when the cistern fills up . Do I need to replace the whole valve ?
Is that the washer that's attached to the white plastic part that moves with the ball cock ? If so that should be an easy fix
Usually inside the filling part. Confused as you say brass then plastic
It is cheap to fit a new one, and easier and quicker than rewashering the old.
I suggest swapping for new, then clean and rewasher the old one at your leisure, and put it in a clean plastic bag to swap back in 20 years when your new one wears out.
