- Joined
- 27 Jan 2008
- Messages
- 23,703
- Reaction score
- 2,670
- Location
- Llanfair Caereinion, Nr Welshpool
- Country
Washing machines and tumble driers now often have weight of cloths or humidity detectors plus a whole host of programs, can't really see point of measuring energy used as it would never be the same twice. However most other items one would hope do have a standard energy consumption.
Counter top dish washer setting 2 which is standard used 0.59 kWh per cycle.
Sky+HD box average 15.8 watts.
Samsumg RL60 Fridge/Freezer 308.54 kWh per annum based on a 700 hour test.
Old Fridge/Freezer with known insulation problems 550 kWh per annum.
However although one can look at manufacturers data for things like the Fridge/Freezer so I know my reading was reasonable close to what it should be, with the dish washer I have no idea as to if that is good or bad. I found a small 32 litre freezer was using 254 kWh per annum so looking to replace it with a chest freezer.
But in the main it costs too much to replace things to replace simply because it is using too much power, but it can help when buying and deciding which to keep when one ends up with two, as we have done when moving in with mother to look after her.
But generally there seems to be no info as to what to expect.
