Obsolete hotplate problem
19 May 2015
Hi.
I,ve got a Rangemaster 110 Electric range and the hotplate with the sensor on it has died. Unfortunately this part is now obsolete. Does anyone know if it is possible to replace this sensor plate with a non sensor one? The people at Rangemaster spares cannot give me an answer as they are just looking at a list of spares on the computer. Thanks.
Have you only tried to obtain Rangemaster one or other manufacturers as well? If you have tried other parts suppliers, then try googling" obsolete parts for ------". I doubt it will be safe to fit a sensorless one but I have no experience of those cookers so cannot say one way or the other for definite.
Yes it is, you have to know what your doing and alter the wiring it is possible, we've done it.
You will need to change the energy regulator, that's easy, depends on the connections on the hotplate. But a standard energy reg, controlling the plate with the sensor would work, you could leave the sensor to fill the hole or by a new hotplate.
Its about having a look at what is there. Appliances are made to take standard & delux items (that's what the sensor is).
(I worked 25 yrs in development of domestic appliances, long time ago, but little has changed in that area)
Thanks for the replies. It looks like the best option is to replace the plate and regulator. Lets hope the regulator isn't obsolete as well!
Cheers.
Strange...I made a post yesterday it hasn't appeared.
Repeat:
You may not need to change the hotplate, you can remove or leave the sensor, just it wont be connected. Without seeing the hotplate terminals its a bit of guess work, can you post a picture of the hotplate terminals, you might be able to save a few £££
