1.If your document already contains text that is formatted with the properties that you want to use, select that text.
If you are starting from a blank document, go to step 2.
2.On the Home tab, click the Font Dialog Box Launcher (this is the little 'arrow' to the right of the word 'Font', and then click the Font tab.
3.Select the options that you want to apply to the default font, such as font style and font size. If you selected text in step 1, the properties of the selected text are set in the dialog box.
4.Click Default, and then click Yes.
