My oil boiler, a Boulter Camray was kettling, so I put some Sentinel in to clean out any build up of scale etc in the heat exchanger.
One month on, I now find the exchanger is leaking! (not sure if it was before, as I have just found water under the lino). Anyway, as the boiler is 12 yrs old I decided to strip it out to find the cause!
I have found 2 stress cracks on the exchanger at the bottom corners, they are near the welds. I suspect they may have been weaknesses when built??? There is NO sign of corrosion inside at all. The welds themselves are looking fine! I am tempted to cut the cracked sections out to investigate!
Any comments on the cause anyone?
