OLD STOPTAP HELP NEEDED
14 Oct 2010
Buckinghamshire
i need to change my internal stoptap as i believe it is restricting flow slightly to house, problem is it is connected to old black poly (about 15 - 20mm in diameter) and i need to know where i can get fittings to connect between black poly and 15mm std copper, incorperating new 15mm stoptap ??
plumbers merchant
could well be 1/2"" alkathene
easiest way is to cut a peice off and take it with you
you will need an adaptor with an insert and a new stoptap :idea:
Might be a compression fitting that works, maybe witha non-metric olive. Depends on whether it's 15 OR 20mm
