Omron my4
29 Dec 2006
Hampshire
I am trying to find if you can buy this relay anywhere local to portsmouth or near or anywhere ? Omron my4 contact 5amp240vac. 5 amp28vdc. coil 220/240vac there is a number 2646w2 on it. my fitter thinks you can no longer buy it? or is there a replacment .?
I think you mean Omron "HY2" ? which is an electronic timer relay, I think they are obsolete, bu you should be able to get a suiable repalcement
try www.rs.com
or Rapid Electronics (not sure of web address)
happy hunting! ;)
my MY4 is a relay that fits into the box in the airing cupboard that connects to the boiler there is no power to the boiler.the fitter says if we cant get this relay a new box will cost about £300 .
this relay comes from a small metal box satchwell sunvac on the wall next to the hot water tank it has a 5 amp fuse +the relay .The fitter says it will be about £300 pound for a new one .what are they called ?
