Hi I have 7 radiators working fine, but one which seems to take much longer to get hot. When checking the flow pipe it is very hot, but return you can hold your hand on for much longer say 2 minutes. Other radiators you will burn yourself. Flushed the rad, nothing but clean clear water with inhibitor in. Balance flow and return on boiler, still the same problem.
Could it be the thermostatic valve sticking.
Hope someone can help.
