Please can anybody help me with this problem. The problem is that the radiator in the downstairs cloakroom will not work. I have taken the radiator off the wall and checked the valves etc.
The pipework to the radiator comes down from the upstairs bedroom. The pipes tee off close to the bedroom radiator which works normally but the pipes never get warm
I have carried out a few tests to no avail. With the CH warmed up I have opened the drain cock and bleed valve with either valve closed and hot water comes down the pipes to the radiator.
I have run the pump and with all other radiators closed hot water does not enter the pipework
If anybody has suggestions to resolve this they would be greatly appreciated. Thank you.
