Hi all,
I had a bit of trouble yesterday with my heating - turned out to be a couple of small (drip) leaks & low system pressure (leaks were inside the boiler)....fixed the leaks & repressurised the system - heating is working perfectly now & pressure is staying put.
The hot water is now playing up a little - the kitchen hot tap (near to the boiler) is working perfectly with constant temperature....the 2 taps in the bathroom give a short burst of hot water (5 secs) & then go luke warm. The boiler seems to be firing normally & nothing else seems out of place....I have noticed one more small leak at the back of the boiler this morning, again this is only a drip - could this be the cause? (I will be fixing this today anyway).
I assume that all the hot water taps will be fed from the same output on the boiler so I'm a little confused about this......any help will be greatfully received.
Tom
Tom
