Opening BG zone valve manually
14 Jan 2009
London
I have been getting RCD trips for a while when I put the CH radiators on.
I can run the hot water consistently with no problem, and if I take the CH electric via its own (RCD) extension from non-RCD side of the distrubution box, it still trips only when I use the radiators. But at least the rest of the power in the house stays on.
I have a Glow Worm Energysaver boiler and a single pump to two zone valves, one for the rads and one for the water. The radiator zone valve is British Gas with the codes BGMVSP-2 and NPC CODE 555212 written on.
I am assuming a problem with the valve rather than the room stat or boiler.
I figured temporarily ( BG can come around middle of next week under my Home Care plan ) to open the zone valve, but to get around the trip I would also need to disconnect the live and neutral wires coming into it. The problem is that the spade connectors do not want to come off. Are they soldered or something?
I can't see it very well at the back of the cupboard and I can't figure out how to remove the box from the pipe either. Hopeless eh?
Can anyone help? Now that the humidity has gone up again it is tripping pretty frequently and my wife is getting a bit fed up with the mains cable strung across the kitchen
hmm. i wouldnt assume anything myself but the valves can do this sometimes with RCD's.
the head should come off the body by pressing the button on the side and pulling.
isolate the electrics and open it up. usually the microswitch is a charred mess.
or, if you remove the valve head and leave it lying on the floor then you can open and close the heating valve with your fingers, then you shouldnt need to find the short until BG get there.
Thanks nickso.
I found the release button round the back and have managed to prise off the brown and blue wires coming into the valve and taped them up. Also managed to turn the valve with pliers. Wait and see, I suppose.
Thanks again
