tritonr1 said:So is it at all possible that it's actually the shower at fault??
its not the shower as that doesnt trip the rcd....if i switch the mcb on to the garage the rcd will trip
tritonr1 said:its not the shower as that doesnt trip the rcd....if i switch the mcb on to the garage the rcd will trip
breezer said:tritonr1 said:its not the shower as that doesnt trip the rcd....if i switch the mcb on to the garage the rcd will trip
wish you had said that in the first place.
it proves its not the cable.
since the cable is always connected, it has to be as i said something else, leave it for today, but did you take the lamps out, and what sort of fittong are they?
I am thinking they may be bulkheads filling with water (AKA flood lights)
breezer said:but the cable is still conected though. (at the house end)
despite what is on or off the earth is connected, so if either core has "gone down" it would make no difference if the garage cu is on or off
its probaly feeding back through something, which is why i said remove all plugs and the lamps.
I wonder how the heaters are connected?
if they are plugged in unplug them too
breezer said:gentlemen (two replies)
read my post again
it probable back feeds when the garage cu is turned on
the swa will be connected on both cores if the mcb is on, the op never said he turned it off.
the op did say the hose rcd trips ehn he turns on the garage cu.
most people (i leant out of the window and asked) said they would leave the house mcb on since there is no need to turn it off.
which there fore means both cores of the swa are connected
